What Is the Best Portable Power Station to Buy?
Product Reviews Tips
19/01/2024
Portable power stations have become a staple for most outdoor enthusiasts and homeowners alike. This is thanks to the convenience they offer when you need a backup power solution. Coming in different sizes and capacities, they can be used in just about any setting: indoor or outdoor. So, how can you choose the best portable power station for your power needs? Let’s find out.
Best Portable Power Stations for 2024
BLUETTI EB3A Portable Power Station | 600W 268Wh
bluetti eb3a
First on the list is this model with a 268Wh capacity ideal for recharging small devices such as laptops and smartphones. This makes it an ideal option for camping and other outdoor related activities. The EB3A has a 1,200W surge power rating, meaning it can run a mini fridge.
With it, you can recharge your laptop at least three times or recharge your drone at least four times. Thanks to the provided nine outlets, you can charge multiple devices simultaneously. And unlike conventional power stations, this model comes with wireless charging capabilities.
For peace of mind, it is equipped with the Battery Management System(BMS), which ensures safe recharging and discharging. You can use the power station for up to 10 years as it is a lithium iron phosphate battery. Whether you want to recharge it using solar panels, a wall socket, or your car’s cigarette lighter, this model got you sorted.
BLUETTI EB70S Portable Power Station | 800W 716Wh
bluetti eb70s
This is yet another workhorse for small power needs. It has a 716Wh capacity and an 800W rated power for running small to medium appliances like a coffee maker or blender. Thanks to the LiFePO4 battery chemistry, you get over 2500 charging cycles. This means you can use it for a decade and still get up to 80% performance.
Like other BLUETTI portable power stations, it comes with numerous outlets such as USB-A, 120V AC, and 12V/10A DC. This allows you to recharge just about any device. Furthermore the wireless charging pad allows you to recharge your iPhone and other similar devices. You don’t have to wait for eight hours to fully charge it. Thanks to the 200W maximum output, you can recharge it within 4 to 4.5 hours.
This model is lightweight, portable, and comes in a compact design. This allows you to transport it to outdoor venues or camping sites with ease. The compact design enables it to fit in tight spaces. If you are looking for a portable yet efficient portable power station, consider buying this model.
bluetti ac180
The BLUETTI AC180 is a must-have power station in your arsenal as it comes with a 1800W power output rating to run most of your appliances. Charging it is a bliss since you can use different power sources. It allows you to recharge using solar panels, wall outlets, and lead-acid batteries, among other sources. And since it has fast charging capability, the 1440W fast charging features allows it to reach 80% within 45 minutes.
Like other BLUETTI power stations, it comes with an app for remote control and monitoring at the comfort of your seat. Equipped with lithium iron phosphate batteries, it can serve you for 10 years. The compact and lightweight design makes it easy to carry it around your campsite.
With it, you can run high-powered devices thanks to the Power LIfting Mode that offers 2700W output power. You can therefore run electric ovens, refrigerators, and electric kettles with ease.
BLUETTI AC200L Portable Power Station | 2,400W 2,048Wh
bluetti ac200l
If you are looking for a workhorse to power your devices while off grid, consider buying this model. Coming with a 3,600W Power Lifting Mode, you can power several high-powered appliances like heating systems and electric kettles. What’s more? The 2,048Wh capacity is adequate to power large appliances such as refrigerators.
Its capacity can be expanded to 4096Wh when connected to a B230 battery. This ensures you have adequate power to run your devices for hours. As you’d expect, it is compatible with fast charging, going from 0 to 80% within 45 minutes. However, this is possible with a 2400W AC input.
You don’t have to rely on solar power to recharge it as there are six ways to go about it. You can choose between AC, lead battery, AC and solar or your car. This versatility makes it ideal for different settings: indoor or outdoor. You also get an app for seamless monitoring and control.
BLUETTI AC200P Portable Power Station | 2,000W 2,000Wh
bluetti ac200p
Finally, the BLUETTI AC200P provides just enough power to run power-hungry appliances for extended periods. Whether you want to power your refrigerator, electric grill, or air conditioner, this model will do the trick. The 2000Wh capacity makes it a reliable backup power option in case of prolonged power outages.
The 4800W surge capacity makes jump-starting your refrigerator or air conditioner seamless without causing damage to the power station. And as a LiFePO4 battery, you get over 3500 charge cycles while enjoying up to 80% efficiency. With 17 outputs, you can rest assured you can plug in just about any household appliance.
There are seven ways to recharge the power station. They range from using AC, solar panels, generators to lead batteries. In short, the power station cannot drain completely regardless of your remoteness. Like other power stations, it is quiet, eco-friendly, and easy to install and use.
How to Choose the Best Portable Power Station for Yourself?
Here are some of the aspects you need to consider when choosing a portable power station:
  • Capacity
Capacity is one the major aspects you need to consider when choosing a portable power station. It is the amount of energy a power station can store. Battery capacity is often measured in kWh (kilowatt-hour) or Wh (Watt hour).
The bigger the battery capacity the more power output it has. Ideally, you’d want to buy one with a higher capacity.
For example, the BLUETTI AC200P has a higher capacity than the BLUETTI EB3A. It means the former can power more devices than the latter.
  • Power Output
Another aspect to consider is the power output. Generally, larger portable power stations have a higher power output than smaller options. It is the rate at which the power station can supply power and is measured in kW (kilowatts) or W (watts).
  • Battery Chemistry
You should also consider the battery technology the portable power station uses. Most models have lithium-ion batteries as they are lighter and more efficient. That said, you can also find power stations with lead acid batteries. Such stations are often bulkier and may require constant maintenance.
BLUETTI power stations come with lithium iron Phosphate batteries that are more efficient, lighter, and have fast charging capabilities. They are also safer than lead acid and conventional lithium-ion batteries.
  • Rated and Surge Wattage
Rated and surge wattage ratings are also important when choosing a portable power station. The rated wattage is the normal power output the portable generator provides while the surge wattage is the power needed to jump start large appliances.
If the generator will be running power-hungry appliances, you’ll need one with surge and rated wattage rating. Otherwise, a power station without a surge wattage will serve you well.
  • Expansion Batteries
Expansion batteries are extra batteries that can be connected to the power station to increase its overall capacity.
Most BLUETTI power stations’ capacity can be expanded by connecting extra batteries. By doing so, you increase the amount of sorted electricity, allowing you to power many devices simultaneously for extended periods.
  • Extra Features
You can also consider additional features that improve usability and convenience. For example, you can look out for app control, inverter upgrades, LED lights, LCD display, and multiple input and output ports.
Related articles: Is It Worth It to Buy a Portable Power Station?
5 Best Small Portable Power Stations for Winter Camping
How Long Can You Run a Portable Power Station?
The amount of hours a portable power station can run depends on several factors such as power consumption, station’s capacity, and the devices being powered. Portable power stations come in different capacities, which is measured in Wh (watt-hours).
To estimate how long a power station can run, divide its capacity by the power consumption of the devices. For example, large portable power stations can power large appliances for at least three hours but power smaller devices for over five hours.
How Many Years Do Portable Power Stations Last?
The lifespan of a portable power station depends on the battery technology. Generally, they can last between 5 and 15 years. However, this depends on the conditions under which it operates. BLUETTI lithium iron phosphate power stations can last for up to 10 years.
Well, the best portable power station you can buy is that which meets your power needs. If you want to charge your devices like laptops, a low-capacity station can be your best bet. On the other hand, if you want to power your entire house, you’ll need a high-capacity station.
