Using A Solar Generator As A Digital Nomad
As a digital nomad, solar generators offer endless potential for exploration.
There are no limits to where you can go, as solar generators provide a cost-effective and renewable option for powering up your devices and staying connected.
Solar generators enable users to stay in touch with their teams while taking advantage of remote working opportunities in a wide selection of locations.
With solar generators, digital nomads no longer need to worry about energy costs or shortages; they can work any place as long as the the sun is shining.
In this article we aim to talk about digital nomads, and how they can use solar generator technology to improve their work flow.
How Many Digital Nomads Live In the U.S.?
According to recent estimates, the digital nomad population in the United States is steadily growing.
With advancements in digital technology, more and more people are choosing to combine their daily work with a wandering way of life, as digital nomads.
The concept of digital nomadism is relatively new, written about as early as 2017; however, the idea has taken off since then.
According to Statista, there are currently around 16.9 million digital nomads living in the U.S. alone. That is over a 100% increase in comparison to the year 2019 when digital nomad figures hovered around 7.3 million.
What appliances can a solar generator power?
For digital nomads who travel extensively and require a portable power source, a solar generator is an ideal solution.
A solar generator has the potential to replace diesel and gas-powered generators and offers a more eco-friendly way to generate power in remote locations.
Solar generators can be used to power all sorts of appliances from laptops and phones to TVs and digital music players.
In addition, it can also be used for charging batteries, running refrigerators, powering air conditioners, or for providing lighting. Therefore, a solar generator can provide digital nomads with a reliable source of electricity wherever they go.
What size solar generator do digital nomads need?
bluetti-ac300
The size of solar generator digital nomads choose will depend largely on their individual needs, as well as the size and type of digital equipment they are carrying.
For digital nomads who carry multiple digital devices with them on their travels, or if their digital equipment has specific energy requirements, a larger capacity solar generator is recommended.
We recommend taking a look at the following BLUETTI solar generator models:
Modern solar generators are becoming more compact, powerful and efficient than ever before. This allows digital nomads to stay charged wherever life takes them without sacrificing space in their luggage.
Solar generators come in sizes for any application and budget.
In order to determine the best size solar generator for your specific needs, there are several components to consider.
To begin, start by determining how much power you will need from the generator at its peak performance during the most rigorous times of use.
This total energy output can then be used to calculate the best size of solar array that is needed in order to provide enough energy during your work flow.
Also consider things like heat management, portability, user-friendliness, and cost when weighing out your options.
The best way to determine your energy needs is to make a quick table highlighting the appliances you aim to power with your solar generator.
Here is an example:
Appliance Wattage  Usage Wh
X1 Led Lights 5 5 hours 25
Laptop 70 2 hours 140
WIFI Device 5 2 hours 10
Total 175 Wh
To calculate the watt hours (Wh) simply multiply your appliance wattage by your estimated usage time.
Once you have completed your own table, you will have a good estimate on what size your solar generator should be in terms of energy storage capabilities.
For example, according to the table above we would need a 175 Wh solar generator with a rated wattage of 80 watts maximum (assuming we want to power all devices at the same time).
In this scenario, our EB3A would be the perfect choice for you.
Travelling with your solar generator
If you're planning to travel with a solar generator, here are some tips you should consider:
  1. Choose the right solar generator: There are many types of solar generators on the market. Choose one that is compact and lightweight for easy transport and has enough energy capacity to meet your needs.
  2. Pack smart: Make sure to protect your generator during transportation. Pack it in a sturdy, weather-resistant case to prevent damage.
  3. Plan your solar panel setup: Consider how you will set up your solar panels to ensure optimal sun exposure. Make sure to have enough panels to generate enough power for your needs.
  4. Be mindful of flight regulations: most airlines allow lithium-ion batteries, up to 100 watt hours (Wh) per battery, to be carried in carry-on or checked baggage. For larger batteries, you may need to get special permission from the airline.
By following these tips, you can ensure a successful and enjoyable trip with your solar generator.
Overall, a solar generator is an excellent choice for anyone looking to have reliable power no matter where they are.
Sizing it correctly is an essential step and with the information shared here, you should be able to figure out what your best option is when it comes to powering up your devices.
For digital nomads, having a solar generator often comes with increased freedom and flexibility since they don't need to rely on external sources of power when they are travelling.
Solar generators can truly make our lives easier, allowing us access to the energy we need whether we're at home or on the go.
It's worth taking some time and researching what type of solar generator would work best for you and how you plan on using it as making the right decision can save you money over time.
