When it comes to renewable energy, solar power is the big dog on the block. It offers both independence from fossil fuels and a way to reduce your impact on the environment at the same time.
However, where you position a solar panel – depending on the type of panel can matter in terms of energy output. But with so many different options available, where should you put portable solar panels?
Here, we will explain the various factors to consider when determining which location works best for you and how it will affect the amount of power you are able to generate.
Factors to Consider When Choosing a Spot for Your Portable Solar Panels
There are several factors to consider when deciding where to place your portable solar panels. Here are some things to keep in mind:
Daily and Seasonal Sunlight Changes
The first thing you need to keep in mind is the amount of sunlight your chosen location receives daily and throughout the year. You also need to consider what time of day it is most beneficial for you to access electricity from your solar panels.
For example, if you live in an area with a lot of snowfall during winter, you will probably want to install your portable solar panels on a south-facing roof so that they can get the most direct sunlight during the winter months when there is not much sun left. On the other hand, if you live in an area where it snows less frequently but has high winds during the winter season, then it would be better if you installed your portable solar panels on a west-facing roof so that they could receive more indirect sunlight at all times of the year.
Weather Patterns
The key is choosing a location for your portable solar panels that is out of the wind but still receives plenty of sun. If you live in an area with frequent storms, it would be wise to choose a location for installing your portable solar panels with less exposure to the wind—the less wind the panels are exposed to, the more they will be able to generate power.
At the same time, if you live in an area where there is high humidity or frequent rainstorms, then it would be best to choose a location for installing your portable solar panels that has more protection from rain and shade from trees—the more protected they are from moisture and wind, the more efficient they will be at generating power.
Accessibility
The next thing you need to consider is the accessibility of your chosen location. If you are planning on installing portable solar panels on your roof, then you need to make sure that there is enough space available for them and that they can be installed safely.
If you have a large family or if your household has many members who will be using electricity from your portable solar panel system, it would be best if you installed them close to where they will be used most often. This way, there will be less distance between the panels and their users, which means more efficient use of energy produced by those panels.
Regulations
The second thing you need to consider when choosing a location for placing the best portable solar panels for your home is whether or not there are any regulations regarding the placement of solar panels on your property. Some local governments have rules regarding how much space needs to be between your house and the edge of the street, how high up on the roof you can put your solar panels, and so on.
If there are no regulations, installing portable solar panels wherever you want them to go will be easier. However, if there are regulations in place, then they will need to be taken into consideration before making any decisions about where exactly you want to install your portable solar panels.
Landscaping Around Your House
The landscaping around your house can be an essential factor to keep in mind when selecting a location for installing portable solar panels. If you have many trees around your home and want to install portable solar panels, you should consider whether any trees are blocking the sunlight from reaching your roof. If there are, you may have to move your portable solar panels away from these trees or trim them down so that they do not block sunlight from reaching your roof.
Unconventional and Optimal Places to Place Your Portable Solar Panels
If you are thinking about installing the best portable solar panels with batteries, you might think that the best place for them is on the roof of your house. But there are other options that may be more effective or even less expensive. Here are some examples of unconventional and optimal places to place your portable solar panels:
Top of Your Garage
The top of your garage is another great location for installing portable solar panels. It is similar to the roof of your car in that it provides plenty of exposure to sunlight, even when there are clouds in the sky. Moreover, installing solar panels on top of your garage means that they will not take up much space inside your home. This makes them an ideal option if you want to generate renewable energy without sacrificing much space or aesthetics inside your home.
The only downside of installing portable solar panels on top of your garage is that they may sometimes be exposed to strong winds. If you live in an area where there are lots of winter storms and high winds, this could mean that the panels will be more prone to damage than they would if they were installed on a different part of your home's exterior.
Fence Around Your House
You can also install portable solar panels on the fence around your house if you want to generate more energy than you can use on a day-to-day basis. This is a good idea because it means that you will not need to worry about moving these panels from one location to charge them up with another.
What is more, installing these solar panels along your fence will be relatively easy and inexpensive because there are no complicated setups involved. All you will need to do is attach them to the fence itself so that they will receive lots of sunlight during the day and store this energy for use at night or on cloudy days.
The Roof of Your Car
If you have a car, this is the perfect place to put your portable solar panels. After all, this location is ideal for many reasons. For one thing, the roof of your car is exposed to plenty of sunlight, even if there are clouds in the sky. This means you will be able to generate lots of power even when there is no perfectly clear day for generating solar energy.
Moreover, installing solar panels on top of your vehicle's roof is convenient because you do not need to find a place inside your home where you can store or set up these panels when they are not generating energy. You will also be able to keep an eye on whether your panels have been installed correctly and are performing optimally without needing to climb ladders or take other risks to adjust them.
By a Window or Skylight
Portable solar panels are ideal for use on the roof of your home or other buildings. However, they can also be installed in different areas near windows and skylights. This is another way to ensure that your panels are exposed to plenty of sun at all times.
If you have a window or skylight in your bedroom or living room, consider installing portable solar panels nearby during the day when you are awake and active at home. Installing these units near windows and skylights can also help reduce the amount of time that it takes for these units to generate enough power for use inside your home.
Moreover, this location is convenient because it allows you to monitor your solar panels and ensure they perform optimally. It also makes sense from a financial perspective. After all, if you have a window or skylight in your home, you can place these panels right by this opening to take full advantage of the natural light coming into your home without investing anything additional. For example, you will not need special windows or skylights fixtures to place these panels there.
The Attic
If you want to install portable solar panels at home, the attic of your house is the ideal location for doing so. This is because attics are usually not used for anything other than storage, so they are a great place to put your portable solar panels without interfering with the rest of your home's functions or decorations.
Additionally, attics are often sunny places where there is plenty of room for installing these panels so that they have plenty of room to generate power on their own. As long as you choose a spot in your attic that gets plenty of sunlight throughout the day, you should be able to generate quite a bit of power, even if you do not have any other energy sources yet.
If there are any electrical outlets already installed in the attic, this will also make it easier for you to set up your portable solar panels without having to worry about where exactly you'll be plugging them in later on.
You have a lot to consider when determining where to set up a solar-powered system for your home. Naturally, planning it out is essential when you have so many factors to consider. Therefore, the more you know ahead of time, the better prepared you will be to make your decision and eventually your purchase. That said, nothing beats hands-on experience with different systems to decide what works and what doesn’t. So if you’ve got questions and want an expert opinion, feel free to contact Bluetti’s customer service. They’ll be happy to assist you.
