Tackling Power Outages with BLUETTI Home Battery Backup
Power Outage
A portable power station is a solar generator that uses movable solar panels to charge a battery. The electricity produced and stored can be used to operate or charge other devices.
As global warming continues to wreak havoc on our planet resulting in extreme weather conditions, melting glaciers, increased temperatures, and more, we need to look for sustainable alternatives to more parts of our daily lives. This involves the move to using solar power stations to generate and store renewable, green energy for our backup power requirements.
A solar power station doesn't just create dependable and renewable electricity from the sun but also minimizes the emissions of dangerous greenhouse gases associated with conventional energy backup systems. Consequently, manufacturers are aiming to improve solar backup generators and make them more dependable than their fuel-powered counterparts.
In this article, we will take a closer look at solar power stations, including their benefits, how long they can last, what you can run on them, and much more.
Benefits of a Solar Power Station
Here are some incredible benefits of a solar power station.
1.     Portable and Lightweight
One major problem with other kinds of solar power generators is that they're too bulky and large to carry around. This makes them difficult to move around and use at any location where you require power other than your workplace or home. The best thing about a portable power station is its compact size – you can easily carry them around for road trips, camping trips, or to events where you need power.
2.     High Utility
You can use solar power stations for a number of different purposes. Whether you have to charge your laptop, phone, or power appliances in an emergency, these systems have got you covered! Some solar power stations come with built-in lights and fans, which makes them highly useful and versatile in a vast number of situations.
3.     Sustainable Source of Energy
A huge problem with conventional power sources is that they aren't eco-friendly. Fortunately, solar power stations don't use any harmful chemicals or burn any fossil fuels to function. This means you won't be negatively impacting the environment as you use the system.
4.     Low Noise
Solar power stations make very little noise as they work. Perhaps the only noise you will hear is the humming of the fan. Moreover, certain models are entirely silent – making them ideal for both outdoors and indoors.
Having a quiet solar power system on standby is important for emergency situations if you wish to keep your peace of mind without getting disturbed by the noise around you.
5.     Low Maintenance Requirements
Solar power stations don't require a lot of maintenance. This makes them one of the most low-maintenance energy sources on the market today. You don't have to undertake any maintenance activities other than keeping your equipment clean. This means you don't have to worry about or spend money on expensive replacement parts or costly repairs.
6.     Numerous Available Options
Solar power stations are available in a variety of sizes and shapes. Thus, you can easily find the right one that suits your particular needs. Whether you need a small generator for charging your devices on camping trips or a large one to power appliances during a power outage, there will surely be an option that will be right for you!
Things to Keep in Mind When Using Solar Power Stations
Even though there are several benefits of using solar power stations, there are a few things you need to be mindful of.
1.     Sensitivity to Temperatures
Some solar generators are unable to withstand prolonged exposure to high temperatures. Thus, you need to make sure that you keep the power station in a cooler place while you keep the solar panels exposed to the maximum amount of sunlight.
2.     Unreliable Source of Energy
The sun's energy is unreliable and inconsistent. There are several areas in the world that have limited sun hours and other weather conditions that impact the effectiveness of solar panels. Solar power stations can only work optimally in subtropical and tropical climates because sunlight is reliable there.
3.     High Initial Costs
The initial investment in a solar power station is quite high and could be a turn-off for a lot of people. Fortunately, the maintenance and running costs are quite low (almost zero), so you don't have to worry too much about incurring regular costs.
4.     Low Energy Storage
Solar power stations are not a good option if your energy requirements are too high. For example, in the event of a power outage, your solar power station might not be adequate to run all appliances and devices in your house. In a lot of cases, they are running a couple of devices at a single time, such as a television, refrigerator, or light.
What Can You Run on a Power Station?
Even though a solar power station can provide electricity without the presence of active sunlight, there are limitations to what it can achieve. For instance, it won't be able to power an entire house, but it can offer comfort during power outages. Appliances such as small refrigerators, televisions, lights, laptop chargers, and phone chargers can easily be operated with a 300-watt solar power station. Additionally, a portable solar power station might be more appropriate for activities such as boondocking or camping.
Certain solar power stations can power more than their watt capacity. They do this by using high-tech charge controllers that enable the device to provide an output higher than 1,000 watts. While your solar power station might die out sooner, it can be helpful in circumstances when you have to charge or use appliances in an emergency.
If you look at the specifics, a regular space heater consumes 1,300 to 1,500 watts of electricity and approximately 700 watts when turned to its lowest setting. This indicates that a lot of solar power stations cannot power a space heater. However, even these more power-consuming appliances can be run if you have the right equipment.
There are solar power stations that can handle it; some can produce energy up to 2,000 watts. Thus, being able to run a space heater is all about owning a power station that's big enough to do so.
If you find this impressive, you can even go a step further. Solar generators can also power a good pump, making them excellent choices for people who live in remote areas where municipal services can be undependable.
How Long Will Power Stations Last?
Generally speaking, a solar power station can last between 25 to 35 years, depending on the quality and brand. While the initial investment is high, it's one that's going to last for a long while. Moreover, several solar power stations come with warranties. Thus, if there is a problem or issue, you can get it repaired.
The Best Solar Power Station
There are several options in the market when it comes to choosing a solar power station. All you need to do is narrow down your options and compare the different features of the systems and then pick one that meets your needs.
Here are our top picks for the best solar power station.
1.     BLUETTI EP500Pro Solar Power Station
The BLUETTI EP500Pro Solar Power Station is a portable power station that produces a 3000W sine wave output. It comes with two different modes, including in-grid UPS mode and flexible UPS mode, along with off-grid power storage. Apart from that, this solar power station provides a flexible recharging method so that you can keep your EP500 on continuously. It also features a smart touchscreen and app remote control.
2.     BLUETTI EP500 Solar Power Station
The BLUETTI EP500 Solar Power Station is another portable power station producing a 2000W sine wave output. It allows you to load multiple devices simultaneously and offers a smart touchscreen, app remote control, flexible charging methods, and off-grid power storage.
3.     BLUETTI EB55 Portable Power Station
The BLUETTI EB55 Portable Power Station has a 537Wh capacity and produces a 700W AC sine wave. It has 12 outputs for multiple devices and six options for recharging (solar, generator, dual AC, Solar + AC, AC, car). Priced at $399, this is a fairly cost-effective power station. Moreover, it's gas-free, quiet, and eco-friendly.
This solar power station is perfect for individuals who are looking for a small source of energy and don't wish to spend large sums of money. It is especially great for outdoor use and can power most small residential appliances. Additionally, the battery is quite efficient, allowing it to store more energy than models with comparable batteries.
Can the BLUETTI Power A Refrigerator?
If you are wondering whether the BLUETTI solar power station can power a refrigerator, you're in for some good news because the answer is yes! The BLUETTI EP500Pro and the BLUETTI EP500 are large enough to power a fridge for a considerable period of time.
What's more, is that there are plenty of benefits of using a solar power station to run a fridge. For instance, if the kWh of electricity costs $0.12, it means you can save $122 by investing in a solar power station. An average solar generator can last for up to 25 years if maintained properly. This means you can save $3050 over the lifetime of the solar power station by making the switch to solar.
And that's not even including the increasing electricity prices and tax credits you get by investing in renewable solar energy. Thus, if you are looking for an off-grid solution to power your refrigerator, solar is surely the way to go!
Bluetti home power stations
Last Few Words
Solar power stations are a smart alternative to conventional gas-powered generators – they are quiet and don't produce any fumes. In addition, they don't generate any harmful emissions, can cut down your carbon footprint, and allow flexible indoor and outdoor operations.
At BLUETTI, we have a vast range of solar power stations and solar generators so you can power your appliances in the most sustainable way possible.
