California is the biggest solar consumer in the United States. The Golden State has also been a longtime advocate of going green with solar. And it makes a lot of sense given that California is a powerhouse of solar innovation and one of the sunniest states in the US with more than 160 days of sunshine per year.
Investing in solar generators also offers a raft of environmental and economic benefits. Perhaps the single most important reason to embrace solar generators in California is for disaster and emergency preparedness.
Disasters in CA
The Golden State is prone to many different disasters that include:
- Floods– Most California communities are at greater risk of flooding, storms, and other related disasters that can cause devastating damage and power outages. It is estimated that roughly 20 percent of the state populace is susceptible to flooding. Floods can happen because of breakages of levees, the collapse of dams, heavy bouts of rainfall, unique topography, and overflowing rivers.
- Wildfire– Frequent episodes of wildfires are a growing pain for residents in California. That’s due to a combination of prolonged spells of drought, arid climate, and dense forests. In the lastsingle year, California has seen more than 800 wildfires that caused over $10 billion in destruction and widespread power outages.
- Earthquakes– Most communities in California stand in areas with active fault lines, which makethem especially prone to earthquakes. California has witnessed some of the most fatal and costliest earthquakes in the US. They usually lead to property destruction, power interruption, and possibly evacuation.
- Landslides– The combination of earthquakes, torrential rainfall, floods, and the nature of topography means Californians are vulnerable to frequent landslides. One of the most fatal landslides in the Golden State occurred in 1969, killing more than 90 people.
California is also known for being vulnerable to power outages, coastal storms, winter storms, and hailstorms. All of these catastrophes can interrupt your connection to the main grid and jeopardize the safety and well-being of your family. That’s why it is a no-brainer to invest in solar generators in California for emergency and disaster readiness.
Top 5 States Where Power Outages Occur
When it comes to dealing with power outages, preparedness is the key. One of the best ways to be ready for such emergencies is to purchase solar generators and other disaster kits.
Here are the top states where power outages are more likely to occur:
1- California
It’s no secret that California is America’s capital of power outages. The Golden State experiences well over 440 major outages each year, rending close to three million residents without electricity.
While around 25 percent of power outages have no particular reason, most of them are caused by inclement weather, wildfires, faulty equipment, and other disasters. These stats make a plausible case for owning solar generators in CA.
2- Texas
Texas is home to the second highest number of power outages in the US. Each year, the Lone Star State sees close to 200 outages that affect more than 1 million households. The biggest culprits include floods and heatwaves, although equipment failure is also fairly commonplace.
3- New York
New York takes position #3 when it comes to power outages. Major outages reported in the state are around 160 and they affect nearly a million people. The most significant factor for the outage is inclement weather that causes nearby trees to fall on live transmission lines.
4- Ohio
As with most Great Lakes states, storms and other weather events are the most probable cause of power outages in Ohio. Outages affect more than 600K homes annually.
5- Michigan
Michigan residents face the most power outages per capita in the US because of inclement weather. Extreme weather events are responsible for over a third of the outages in the state.
Benefits of Solar Generators in California
SDG&E, SCE, PG&E, and other utility companies often turn off power to a large number of homes to curb wildfires, especially in wooded northern parts of California. Floods, earthquakes, landslides, and faulty equipment are also likely to render your home without electricity.
Make sure you and your loved ones aren’t left out of touch and in the dark with solar generators. Not just that; solar generators offer a wide range of other benefits that include:
1- They save you money
When it comes to disaster preparedness or going off-grid, solar generators make the most sense financially. They have far much lower costs of operation than gasoline-powered generators. While the upfront cost of solar generators is significant, it will save you money in the long run.
Another way to make the most of your investment is to use your solar generator at night when it is expensive. Remember, utility firms in California have increased the electricity rates between 4 pm and 9 pm. That could potentially add around 10 percent to your monthly bill.
Your solar generator will produce and store electrical power in the daytime. As such, you can use the battery-stored power at night when the grid rate is more expensive; helping you cut your utility bill.
2- Quiet and fume-less
Solar generators use free sunlight energy rather than fossil fuels. They don’t have any moving parts, meaning the solar-powered generators are pleasantly quiet. They need minimum to no repairs.
Besides, these solar units don’t emit odors, fumes, or any by-products that are hazardous to you and your family or the environment. That makes them a safer and more eco-friendly option to gas-powered generators.
3- Free, abundant, and renewable fuel from the sun
Standard gas-powered generators will force you to buy the ever-expensive fossil fuel. With a solar generator in CA, there’s no fuel cost because it uses the light rays from the sun. Even better, most communities in California receive more than 160 days of full sun each year.
4- Environmentally-friendly
When you get solar generators, you don’t need to buy gasoline to prepare for disasters, emergencies, and power outages. They use the ever-abundant sunshine and produce clean energy, making them an eco-friendly option for your use.
More than that, solar generators operate silently, so you don’t have to concern about disturbing your neighbors and causing noise pollution.
5- Low maintenance
A typical gasoline-powered generator will require routine replacement of fuel switches, air filters, spark plugs, and whatnot. With a solar generator, that’s a thing of the past. It’s practically low maintenance.
6- Take the power wherever you need it
Top-notch solar generators in California are highly portable, so you can have an electrical power source wherever you need it. You can use your solar generator for camping, RV living, road-tripping, and off-grid living. It’s a reliable source, especially in remote regions far removed from the main grid.
Recommended Solar Generators
It pays to keep the following important factors when choosing a solar generator to buy in California:
- Battery capacity
- Your energy needs
- Size (both the weight & dimension)
- Cost
With that being said, some of the most recommended solar generators in CA include:
Bluetti EB55 537WH/700W Portable Power Station
Key Specs
- Battery Capacity: 32,000mAh 22.4V/537Wh
- Dimensions: 10.94 x 7.8 x 7.79 inches
- Weight: 16.5lbs
Bluetti EB55 is an excellent choice for disaster preparedness and anyone with modest charging needs during camping, off-grid living, RVing, or other outdoor activities. It is relatively portable at just 16.5 pounds. It accepts 400W of solar power via dual input, allowing it to reach full charge in no more than 2 hours.
Pros
- Enough capacity to run essential appliances, from a coffee maker to laptop and more
- Strong built-in inverter and four 110V pure sine wave AC outlets
- Comes with a wireless charging pad
BLUETTI EB240 2400WH/1000W Portable Power Station
Key Specs
- Battery Capacity: 2400Wh/1000W
- Dimensions: 10.94 x 6.4 x 14.4 inches
- Weight: 48.5lbs
This unit outputs power at 2400WH, making it a perfect option for disaster readiness, RV living, and outdoor activities. It boasts a smart LCD touch screen for easy control. It’s a little heavier but features an ergonomic handle and plenty of ports for additional power to charge many devices at once.
Pros
- Easy to use with touchscreen LCD display
- Enough capacity to power through several days of disaster and power outages
- Multiple outlets and ports
Key Specs
- Battery Capacity: Built-in 2048Wh, Expandable up to 6,144Wh
- Dimensions: 16.5 x 11 x 15.2 inches
- Weight: 61.9 lbs
If you live in an area that experiences longer power outages, like to spend numerous days camping, or wish to embrace off-grid living, the Bluetti AC200MAX is worth considering. With built-in 2048 watt-hours of charging capacity, the AC200MAX packs punch and will keep your appliances and lights running for hours.
Pros
- Tons of capacity: 2048Wh built-in
- Battery capacity expandable
- Comes with two 15W wireless charging pads
FAQ:
1. Is a solar generator a good investment?
Yes, a solar generator is a good investment because it uses free sunshine, generates clean renewable energy, and uses no fuel. It is also low maintenance and quiet to run.
2. Is solar energy good for California?
Absolutely! California experiences a wide array of disasters that lead to frequent power outages, making solar energy a viable alternative. Solar energy is also great for you, your family, and the environment. It is a win-win for the state of California.
3. Can I install my own solar panels in California?
Yes, you can install your own solar panels in California. However, you will need to get a permit and have the know-how and tools to do so.
California is a solar state and one of the biggest advocates of going solar in the US. For many, solar generators in CA are a worthy investment due to frequent power outages resulting from wildfires, floods, equipment failure, landslides, and other natural disasters.
