Air conditioners require a lot of power to run but are essential to cool down the house especially in the hot days. A lot of energy means it is difficult to run them utilizing solar power. Still, some fine pieces of machinery are able to power air conditioners for up to ten hours (wall units), or more when it comes to portable one.
Scroll down to find the best solar generator for air conditioners. You will also determine if all the power generators in the market could run air conditioners or not. Plus, you will learn about the power required to run air conditioners. Moreover, a part of this guide is dedicated to the solar generator for RV air conditioners, given that's where you’ll need the solar generator the most.
How many watts do air conditioners need to start?
Different air conditioners, depending on the capacity and manufacturer, require different amounts of power to start and run. You could easily find out this information by referring to the specification manual that comes during the purchase.You can also contact the sales for the requirements of power for the particularly made model. Still, here are some rough estimations of the average portable AC and wall units requirements:
AC BTU Size |
Initial Surge Watts Required |
Running Watts Required |
5000 |
1000-1500W |
200W-500W |
7000 |
1400W-2000W |
400W-700W |
10000 |
1700W-2200W |
500W-800W |
13500 |
2500W-3000W |
700W-1500W |
15000 |
2800W-3500W |
800W-1500W |
How Long Can A Solar Generator Run An Air Conditioner?
Well, it depends on the standard of your air conditioner, i.e., the power required to run the particular air conditioner. If the solar generator features a higher storing capacity, like the ones we recommend later in this guide, then your AC could run as long as three to seven hours constantly.
As mentioned earlier, on average — an air conditioner requires 1KW of power to run, and the average solar power generators in the market range from 1KW to 4KW. No matter what, never choose a product whose capacity is less than 1KW when looking for a solar generator for air conditioners.
You had better be careful that the solar generator can deliver 3KW of power, as sometimes the air conditioner could demand more and usually would run the air conditioner for a few hours.
So, you could consider a low BTU AC unit to run it for more hours. A good solar generator with a reliable battery capacity can run AC units for up to 16 hours. Later in this guide, you will find products that could run AC units even longer.
BLUETTI Elite 400 Portable Power Station
Designed for extended outdoor adventures and higher power demands, the BLUETTI Elite 400 combines a large 3,840Wh battery capacity with 2,600W AC output, making it a reliable solar generator option for running air conditioners, RV appliances, and other power-hungry devices.
With its high-capacity LiFePO4 battery and solar charging capability, the Elite 400 provides longer runtime compared with smaller portable power stations. It is ideal for users who need dependable power for camping, road trips, vanlife, and off-grid cooling solutions.
The Elite 400 also supports multiple charging methods, including AC and solar charging, allowing you to recharge efficiently wherever your adventure takes you.
For users looking for a portable yet powerful solution to support air conditioners and essential appliances, the BLUETTI Elite 400 offers the flexibility needed for extended outdoor and backup power scenarios.
Can You Use Solar Generators to Run an RV AC?
The short answer is yes. With the right setup, a solar generator can run an RV air conditioner and provide reliable cooling when traveling off-grid. Compared with traditional power sources, a properly sized solar generator offers a cleaner and more flexible way to power RV appliances, including air conditioners, refrigerators, and other essential devices.
Choosing the right solar generator for an RV depends on several factors, including the air conditioner’s running wattage, startup surge power, battery capacity, and available solar input. You can learn more about choosing the right setup in our RV solar generator series.
Most RV air conditioners require around 1,700 to 3,500 watts of surge power and approximately 600 to 1,500 watts of running power. Therefore, selecting a solar generator with sufficient output capacity and battery storage is essential to ensure your RV AC can operate efficiently for extended periods.
What are the benefits of solar on an RV?
Getting off the grid is one of the best ways to cut down the costs of monthly expenditure. So, when it comes to RV — the most significant advantage of using solar power is that you do not have to wait at stations to recharge your batteries and pay for it. But that is not the only benefit of solar power on an RV; you’ll also benefit from:
- Ease of traveling and ‘true’ freedom: most people consider RVs for the ‘freedom to travel.’ Nevertheless, that freedom takes a hit when you have to recharge batteries to run the essential gadgets and devices. Since you’ll have to stick to areas where battery recharge is possible. But that is not the case when it comes to solar-powered RVs; you could turn to any direction without any worry.
- Light on the environment: are you climate-conscious? Well, then what’s wrong with the renewable source of energy.
- Operates in silence: compared to the fuel-generators — the solar-powered stations do not produce any noise nor require you to stop whenever you’ve to recharge the batteries.
Other ways to keep RV cool down
Well, an air conditioner is not the only way to keep your RV cool. You could also consider other ways like:
- Always park the RV under shade — after you’ve charged the solar panels.
- Purchase a fan.
- Stay at an RV campground and avail of their amenities.
FAQ:
Q: Can a solar generator power an air conditioner?
A: Yes. A solar generator power station could run an air conditioner for multiple hours. But not all power stations are able enough to run air conditioners. You’ll have to consider the surge and running power requirements of the particular air conditioner. And accordingly, purchase a solar power station that delivers more power.
Q: How many solar watts do you need to run an air conditioner?
A: It depends on the individual air conditioner requirements. For instance, a typical small RV air conditioner requires 1700 surge and 700 running watts — so a battery bank capable of delivering that amount of power would be sufficient to run an air conditioner for hours.
Q: Which solar generator can I choose to run an air conditioner?
A: The right solar generator depends on your RV or air conditioner's power requirements, including running watts, startup surge, battery capacity, and expected runtime. For portable cooling needs, the BLUETTI Elite 200 V2 provides a powerful and compact solution with 2,600W AC output and 2,073.6Wh capacity. For longer trips, higher energy demands, or running more devices alongside an air conditioner, the BLUETTI Elite 400 offers increased capacity with 3,840Wh of energy storage.
For more guidance on selecting the right setup for your RV, explore our RV solar generator solutions.
Q: What is the biggest problem with solar energy?
A: The most significant problem with solar energy is the lack of energy on a cloudy day, whis is the reaseon why we recommend products that could be charged via a variety of means.
As you have read, a solar generator for an air conditioner is not troublesome to find. And yes, a solar power station could run an air conditioner for hours. But as specified earlier, you’ll need to check the surge and running power of the air conditioner before purchasing to make sure its capacity can satisfy your needs.
