What Size Solar Generator Do I Need For My AC?
solar generator for home
In California, from May 31 to September 16, the average daily temperature sits above 78°F, while the hottest month of the year is July. During this month you could expect temperatures with an average high of 86°F and low of 71°F.
While in Jacksonville Florida, the highest temperature recorded in 2021 was 108°F.
Why are we telling you this?
Well, we are demonstrating just how hot it can get in the U.S., particularly in states like California, Texas and Florida.
It is for this reason that air conditioners have long been one of the most popular appliances in homes and RV's alike.
In this article we aim to talk about AC power consumption and what size solar generator you would need to power one.
Average Temperatures Throughout The U.S.
Rank Average Temperature ▼ State / Population
1. 72.95°F Hawaii / 1,392,704
2. 71.80°F Florida / 19,361,792
3. 66.74°F Louisiana / 4,601,049
4. 65.97°F Arizona / 6,561,516
5. 65.97°F Texas / 26,092,033
6. 63.50°F Mississippi / 2,984,345
7. 62.68°F Alabama / 4,817,678
8. 62.30°F Georgia / 9,907,756
9. 61.70°F South Carolina / 4,727,273
10. 61.17°F California / 38,066,920
11. 60.14°F Oklahoma / 3,818,851
12. 60.09°F Arkansas / 2,947,036
13. 58.70°F North Carolina / 9,750,405
14. 58.11°F Tennessee / 6,451,365
15. 57.30°F Nevada / 2,761,584
16. 55.62°F Kentucky / 4,383,272
17. 55.54°F Virginia / 8,185,131
18. 54.73°F District of Columbia / 633,736
19. 54.70°F Missouri / 6,028,076
20. 54.68°F Kansas / 2,882,946
21. 54.61°F Maryland / 5,887,776
22. 54.48°F Delaware / 917,060
23. 53.08°F West Virginia / 1,853,881
24. 53.07°F New Mexico / 2,080,085
25. 51.93°F New Jersey / 8,874,374
26. 51.81°F Indiana / 6,542,411
27. 51.37°F Illinois / 12,868,747
28. 51.27°F Oregon / 3,900,343
29. 50.88°F Ohio / 11,560,380
30. 50.47°F Washington / 6,899,123
31. 49.88°F Nebraska / 1,855,617
32. 49.80°F Pennsylvania / 12,758,729
33. 49.55°F Utah / 2,858,111
34. 49.27°F Rhode Island / 1,053,252
35. 48.60°F Connecticut / 3,592,053
36. 48.17°F New York / 19,594,330
37. 48.14°F Massachusetts / 6,657,291
38. 48.14°F Iowa / 3,078,116
39. 46.64°F Michigan / 9,889,024
40. 46.32°F Idaho / 1,599,464
41. 46.26°F Colorado / 5,197,580
42. 45.54°F South Dakota / 834,708
43. 44.71°F Wisconsin / 5,724,692
44. 44.49°F New Hampshire / 1,321,069
45. 44.18°F Montana / 1,006,370
46. 43.74°F Vermont / 626,358
47. 43.47°F Wyoming / 575,251
48. 43.09°F Maine / 1,328,535
49. 42.98°F Minnesota / 5,383,661
50. 40.80°F North Dakota / 704,925
51. 32.03°F Alaska / 728,300
How Much Energy Does An AC Consume?
This all comes down to the model of AC you decide to buy. All you need to work out the energy consumption of your air conditioner is the power rating, and the amount of time you plan to use the appliance for.
So for example, let's assume you buy a mid-sized AC unit, this is likely to consume on average 1000 watts. However, it does all come down to the size and type of unit you get.
Another unit of measurement you should look at is the BTU rating.
The BTU rating is the measurement of an AC's cooling capacity, that capacity can also give you an idea of how many watts it consumes:
BTU AC Watts
5,000 41 - 625
10,000 833 - 1500
15,000 1250 - 2250
It is important to remember that air conditioners generally have a much lower running wattage than their stated power rating. This is because these appliances cycle on an off throughout the day.
Generally, air conditioners cycle on and off 2-3 times each hour for about 15-20 minutes at a time.
This means that a 3000-watt air conditioner really uses about 1,950 watts each hour, and a 1000-watt AC unit uses about 650 watts each hour.
How To Calculate Your Energy Requirements
Now that we have some understanding on how many watts an air conditioner consumes, we can use a simple formula to work out what size solar generator we would need to power it.
Running an air conditioner with solar power requires more than just a portable battery. Because AC units have high startup power requirements and consume significant energy over time, choosing the right solar generator depends on the inverter output, battery capacity, and how long you need cooling support.
For example, a 1,000-watt air conditioner may not continuously consume 1,000 watts because the compressor cycles on and off throughout operation. However, you still need a solar generator with enough output capacity to handle startup loads and enough battery storage to maintain power for extended periods.
What Size Solar Generator Do You Need To Run An Air Conditioner?
The size of the solar generator required depends mainly on three factors:
  • Air Conditioner Wattage: Larger AC units require more inverter power and battery capacity.
  • Battery Capacity: A larger battery allows the solar generator to run the air conditioner for a longer period.
  • Cooling Environment: Temperature, insulation, room size, and thermostat settings all affect actual energy consumption.
For occasional cooling during short power outages, a smaller system may be enough. However, for extended backup power, RV air conditioning, or off-grid living, an expandable solar generator system provides much greater flexibility.
Best Solar Generators To Power An Air Conditioner—BLUETTI Apex 300 + B300K
The BLUETTI Apex 300 + B300K is designed for users who need reliable power for high-demand appliances such as air conditioners. Unlike smaller portable power stations, the Apex 300 system provides higher output capability and expandable battery storage, making it suitable for home backup, RV cooling, and off-grid applications.
Key Features of Apex 300 + B300K:
  • 3,840W AC Output: Provides enough power capacity to support demanding appliances, including air conditioners, refrigerators, and other household essentials.
  • Expandable Battery Storage: Pair with B300K expansion batteries to increase energy capacity and extend backup runtime based on your cooling needs.
  • LiFePO₄ Battery Technology: Delivers long-lasting performance, improved safety, and reliable daily energy storage.
  • Solar Charging Support: Recharge using solar energy to create a cleaner and more independent power solution.
  • 120V/240V Compatibility: Suitable for a wider range of home backup and high-power applications.
  • Smart Energy Management: Monitor and manage your energy usage through intelligent controls and app connectivity.
How Long Can A Solar Generator Run A 1000W Air Conditioner?
The runtime of a solar generator depends on the available battery capacity and the actual power consumption of the air conditioner.
For example, a 1,000W AC unit running continuously would consume approximately 1,000Wh of energy every hour. However, because most air conditioners cycle between active cooling and standby operation, real-world consumption is usually lower.
A larger battery system can significantly extend cooling time. By adding B300K expansion batteries, the Apex 300 system provides additional stored energy, making it better suited for longer outages or extended off-grid use.
Why Use A Solar Generator Instead Of A Gas Generator For Air Conditioning?
Traditional gas generators can provide strong power output, but they require fuel, produce noise, and create emissions during operation. Solar generators offer a quieter and cleaner alternative by combining rechargeable battery storage with renewable solar energy.
For homeowners, RV owners, and off-grid users, a solar generator provides the convenience of reliable electricity without the need to store gasoline or deal with generator maintenance.
We hope this article gave you a better idea on the best solar generators to power an air conditioner.
Always remember that when it comes to appliances that consume high amounts of electricity, you don't want to skimp on energy capacity when choosing your solar generator.
