People often run away from the hustle and bustle of the city by going out for camping. While a true journey away from a civilization requires a power source that is a generator.
However, selecting a generator that will meet your camping needs can take time and effort. Numerous varieties of generators come in different sizes. So, our guide to finding the right-size Generator will lay everything on the table so that you can pick a Camping Generator that is fit for you.
Why You Need a Generator For Camping?
Camping is a top way of communion with nature and fleeing from the city noise. Camping in nature may mean being off the grid, forced to use only nature's provided tools for igniting your fire, and creating your sources of heat and light without any electricity. However, we have smartphones, cameras, portable speakers, and other similar devices which must be charged. Therefore, a camping generator is a must-have to take care of items such as device charging, non-battery lighting, cooking appliances, and refrigerators, among many others.
What is the Right-Sized generator for camping?
Power
Here's a quick rundown of common camping devices and their wattage:
Laptop – 60-80 watts
Television – 120 watts
Coffee maker – 600 watts
Mini fridge – 500 watts
Portable heaters – 250-1500 watts
Camping stoves and ovens – 100-1500 watts
As you can note, camping cooking devices and heaters consume more energy compared to others in the list of gadgets. For you to power them, you will require a generator with at least 1500 watts of output power.
Surely, you will not run the devices simultaneously. You may be able to do just with a portable generator providing 800W if these are all of your electric requirements, like running a small desktop computer and mini-fridge at once.
Generators are labeled as the running wattage or the peak surge wattage. The running wattage is the amount of power that the set can sustain for long hours or continuously. On the other hand, the peak surge wattage defines the output capacity of the generator.
The ideal generator for you should be able to handle the starting watts of your appliances. For instance, you will need a generator with a starting power of at least 1,100 watts in order to run both your coffee maker and mini fridge. The starting watts are higher and should, therefore, be factored in while determining the generator size.
Type
These include gasoline, diesel, gas, and solar-powered generators. However, not all of them can be used in camps. Among all types of generators, the most common is portable ones. They are small and portable hence good for use in camping. Solar generators are normally portable generators. They operate on solar power, thus making you not worry about being short of fuel. Apart from that, solar generators are also quiet, unlike diesel generators; hence, they will not disturb your camper neighbors.
Conventional generators run on petrol and gasoline. They are usually louder, run longer, and consume fuel, though they are generally stronger than others.
Things To Consider In Generators
Wattage
First of all, you need to ask yourself how much power you want. Indeed, every camper's camping generator needs will be different. For example, if you only need to recharge your smartphones, laptops, and fans, then go for a small solar generator.
However, if you need a generator for running more appliances continuously, go for a large recreational camping generator. Tally the starting watts of all the things you need to power then purchase a generator with high enough power for that purpose. Oversizing the generator by approximately 20% should always be done because you wish to avoid having a constant run at 100% load.
Noise Level
You will not wish to have a super loud generator that is hated by everybody on the campground. Therefore, there are then some decibel-limits depending on which place you will camp, and going overboard may lead to either expulsion or a massive fine.
Solar camping generators do not have an internal combustion engine and hence, there is no noise made by them, making them the quietest camping generators.
Fuel Type
Camping generators can be powered by gasoline, propane, and solar energy. Some dual-fuel generators even let you flip between fuel options such as propane and gasoline to give you some variety. Nevertheless, high fuel costs, noisy engines, and pollution will soon undermine the utility of gas-powered items in camping. On the other hand, solar generators have been making their impact because of their environment-friendliness and hushed operation.
Clean Power
Clean power is essential for some of the most valuable devices that you would like to work on during your camp, for instance, your cell phone. The genset must have a THD of less than 5%. Your device gets fried any amount that exceeds this limit.
This kind of clean power is only assured by both the inverter and solar generators. You can use your smartphone, laptop, tablet, and other devices with no worries.
Portability And Ease Of Use
You should always remember to take into account the size and weight of a generator while making a purchase. However, it will affect your usage of this generator. Hence, please choose a light one. Carrying a heavy generator for camping would be tougher as it would take longer before one can move around the campsite.
Ensure you choose a portable camping generator that is lightweight and easy to transport without missing out on the additional useful qualities needed. It should be user-friendly and operable.
Related articles: What Size Portable Generator Do I Need for Camping?
Calculating Watt Usage for Camping
Let's now turn to simple mathematics. To estimate your power needs, use the formula:
Watts × Run time= watt-hours
Therefore, if you use 100-watt appliance for 2 hours, you will consume 200 watt-hours.
3 Handpicked Solar Generator Kits
BLUETTI Elite 400 Solar Generator Kit
BLUETTI Elite 400 solar generator provides powerful and reliable energy for camping, RV trips, and off-grid adventures. With a large 3,840Wh LiFePO₄ battery and 2,600W AC output, it can support a wide range of devices and appliances, including laptops, cameras, lights, refrigerators, and other outdoor essentials.
Built with advanced LiFePO₄ battery technology and an intelligent Battery Management System (BMS), the Elite 400 delivers long-lasting performance, enhanced safety, and reliable power management. When paired with compatible BLUETTI solar panels, it allows you to recharge using clean solar energy and stay powered during extended outdoor adventures.
The Elite 400 solar generator kit is designed for travelers who need dependable power without relying on traditional fuel generators. Whether you're camping in remote locations, traveling by RV, or preparing for emergency situations, it provides a flexible and convenient energy solution wherever you go.
With multiple charging options, including AC outlets, USB ports, and DC outputs, the Elite 400 makes it easy to keep essential devices powered during your journey. From charging personal electronics to supporting outdoor appliances, it helps create a more comfortable and connected camping experience.
BLUETTI Elite 200 V2 Solar Generator Kit
The perfect power companion for your camping adventures is the BLUETTI Elite 200 V2 . Designed with a powerful 2,073.6Wh LiFePO₄ battery and 2,600W AC output, it provides reliable and portable energy for camping trips, RV travel, outdoor activities, and off-grid adventures. Whether you need to charge electronics, run camping equipment, or power essential appliances, the Elite 200 V2 delivers dependable performance wherever you go.
Built with advanced LiFePO₄ battery technology, the Elite 200 V2 offers long-lasting durability and improved safety for outdoor use. Its intelligent Battery Management System (BMS) continuously monitors battery performance and helps protect against overcharging, overheating, overcurrent, and short circuits, ensuring a safer power experience during every adventure.
The Elite 200 V2 can be paired with compatible BLUETTI solar panels to create a complete solar generator setup. By using clean solar energy to recharge your power station, you can enjoy greater energy independence during camping trips, road travel, and remote outdoor exploration without relying on traditional power sources.
With multiple output ports, the Elite 200 V2 allows you to power various devices at the same time, including phones, laptops, cameras, lights, and other outdoor essentials. Its compact and powerful design makes it an ideal choice for travelers who want reliable electricity while keeping their setup lightweight and convenient.
Whether you are exploring remote locations, enjoying a weekend camping trip, or preparing for unexpected power interruptions, the BLUETTI Elite 200 V2 provides a quiet, efficient, and flexible power solution for modern outdoor lifestyles.
BLUETTI Apex 300 + B300K Solar Generator Kit
BLUETTI Apex 300 + B300K is a powerful and expandable solar generator system designed for home backup, outdoor adventures, and off-grid energy needs. With a high-output inverter and expandable battery storage, it provides reliable power for essential appliances, electronics, and outdoor equipment when traditional power sources are unavailable.
Whether you are preparing for unexpected household blackouts or building an independent energy setup for outdoor living, the Apex 300 + B300K delivers flexible and dependable power. Its expandable design allows users to increase battery capacity based on their specific energy needs, making it suitable for longer backup periods and higher power demands.
The Apex 300 + B300K can also be paired with compatible BLUETTI solar panels to create a complete solar energy system. By capturing clean solar power during the day, users can recharge their battery storage and maintain greater energy independence during camping trips, emergencies, and off-grid applications.
Built with advanced LiFePO₄ battery technology and intelligent energy management, the Apex 300 system provides enhanced safety, durability, and long-term performance. It is designed to support a wide range of applications, from powering household essentials during outages to providing reliable electricity for remote locations.
With smart monitoring features and flexible expansion options, the Apex 300 + B300K offers a future-ready power solution for users who need more than a standard portable power station. Whether for home backup, RV travel, or off-grid living, it delivers reliable energy wherever you need it.
However, this is different from where the awesomeness ends. The Apex300 is a power wizard. It could also link up with a network, accessing updates that will improve its functionality over some time. It's never done; there is no end limit to its goodness!
Cautionary Procedures Applicable To Generators While Camping
Although a generator enhances the camping experience, it may be harmful when misused. Here are a few things to keep in mind when using a generator while camping:
Before use, read the generator's manual. It sounds obvious, but it is a surprising number of those who neglect this rule. The manual will contain essential safety instructions on operating the generator. An important thing to note is that you do not use generators in the tent or RV. If enclosed in a small space, the exhaust coming from the generator can be lethal, but this is not the case with solar generators.
Ensure that there is ample circulation within the generator to prevent overheating or fires. Carbon dioxide is released through the exhaust of the generator. With time, it can develop a lethal effect if it accumulates in an area. The fact is that you should never run a generator close to open water. Water can also cause the generator to spark and start a fire if placed close to it.
Keep in mind that it doesn’t need to be something big and heavy, but you do want it strong enough for all your appliances. OK, so look at all the stuff you need to run that needs power and that will give you an idea of how big a generator is necessary on your next trip.
