How Many Watts Does a Coffee Maker Use?
Home Appliances
11/08/2026
Do you love coffee? I know I do. And a coffee maker is a blessing for us coffee-minded people. But have you ever wondered how many watts does a coffee maker use?  Find out how many watts does a coffee maker use, what factors affect its consumption, what chuck it takes from your energy bill, and some great recommendations like switching to solar.
Basic Electrical Terminologies
Before we begin, let us gain an understanding of the basic terminologies about electrical consumption that you will encounter in this article.
Watt (W): Watt is the basic unit of power, equal to one joule per second.
Power: Power is the amount of electricity an appliance consumes at a given time. Hence, how many watts does a coffee maker use refers to the electricity consumed by a coffee maker at one time.
Kilowatt (kW): Normally, the digits of power are relatively high; thus, it is preferred to use kilowatts instead of watts. This is because 1 kilowatt is equal to 1,000 watts.
Kilowatt-hours (kWh): Your utility bill at the end of the month has the electrical consumption in kilowatt-hours. It refers to one kilowatt of power per hour.
The electrical consumption of an appliance is the power usage that makes up your monthly electricity bill.
Energy Consumption Factors For Coffee Makers
Generally, a typical coffee maker uses about 700W to 1,500W, depending on the model, brand, and make. Yet, how many watts does a coffee maker use can vary depending on the type, size, and features of a coffee maker and the time it requires to make coffee. Therefore, you cannot rely on just one factor to ascertain how many watts does your coffee maker use; all aspects matter.
Let’s delve right into them.
1. Type
    Various types of coffee makers are now found in the market. Some examples include drip coffee makers, espresso machines, and single-serve coffee makers. You must own at least one of them, don’t you? Well, the news is that drip coffee makers are the most energy-efficient, i.e., they require the least amount of power to generate coffee.
    Espresso machines are less energy-efficient than drip coffee makers, while single-serve coffee makers need the most power to produce coffee. Undoubtedly, more power consumption means more utility bills.
    2. Size
    It must be cliche, but yes, a larger size requires greater power to make coffee. So, if you own a larger-sized coffee maker, it will definitely consume more electricity when compared to owning a smaller-sized coffee maker.
    3. Features
    Advanced coffee makers now come with super enticing additional features that make you want to buy that coffee maker right away. But wait! What about their power consumption? That’s right.
    Additional features - such as warming plates and timers - will also cost you more in terms of your electricity consumption and, thus, your utility bill. So, better think thrice before directly going for the most tempting coffee maker to buy.
    4. Brew Time and Heating Duration
      How long does your coffee maker take to make coffee? The longer time it takes, the longer the device stays plugged to a socket, the more power it will consume. Naturally, the opposite is also true. The less time your coffee maker requires, the less power it will consume, and the less it will add to your utility bill. Of course, the time duration is not all that matters. Other factors contribute just as much.
      Energy Consumption of Common Kitchen Appliances
      A kitchen uses not just a coffee maker. Many other devices, such as microwaves, refrigerators, toasters, kettles, blenders, and others, are common electrical appliances used daily in the kitchen. Let us explore how many watts does a coffee maker use when compared to other kitchen appliances, shall we? Coffee makers have an energy consumption rate from 700W to 1,500W. What about the others?
      Microwaves: Microwaves consume 600W to 1,200W of power; thus, they have a similar range to coffee makers. Therefore, microwaves utilize almost the same power that coffee makers do.
      Refrigerators: Our ever-reliant storage device, refrigerators use up merely 300W to 800W of power, much less than coffee makers. Yet, refrigerators work continuously, unlike coffee makers that only remain plugged in for a few minutes. Hence, refrigerators’ power consumption is not exactly less either. Find out the best power generator for refrigerators when there is a power outage.
      Toasters: Ranging from 800W to 1,500W, toasted also lie in the same category of power consumption as coffee makers. Like coffee makers, they, too, consume power only for short intervals.
      Blender: Blenders consume power ranging from 500W to 700W. They also operate for short intervals; thus, blenders consume less power than coffee makers.
      Kettles: Electric kettles have a power consumption ranging from 1,200W to 1,500W. Like coffee makers, they operate for short intervals; their power consumption is similar to coffee makers.
      Kitchen Appliances
      Wattage
      Coffee maker
      700W to 1,500W
      Microwave
      600W to 1,200W
      Refrigerator
      300W to 800W
      Toaster
      800W to 1,500W
      Blender
      500W to 700W
      Kettle
      1,200W to 1,500W
      How Many Watts Does a TV Use? Save Cost Solutions
      How Many Watts Does a Window AC Use?
      Find out how you can easily calculate the power your coffee maker consumes in one usage.
      The Data:
      How many watts does a coffee maker use?
      Time duration required to make coffee
      The average cost per kWh in your area/state
      Example:
      Let the wattage of your coffee maker be:  2,000W
      Let the time duration: 2 minutes
      Let the cost per kWh in your area: 13.19 cents
      Conversions:
      Converting watts to kilowatts: 2000/1000 = 2kW (1kW = 1,000W)
      Converting minutes to hours: 2/60 = 0.03 hours (1 hour = 60 minutes)
      Converting cents to dollars: 13.19/100 = $0.13 ($1 = 100 cents)
      The procedure:
      Power = time * wattage
                 = 0.03 * 2
                 = 0.06 kWh
      The utility bill per one usage = power * cost
                                                     = 0.06 * 0.13
                                                     = $0.0078
      Monthly bill = 0.0078 * 30
                           = $0.234 / 23.4 cents
      Therefore, the cost of making your coffee for 2 minutes with a 2,000W coffee maker is $0.0078 in one usage, while the monthly cost is $0.234. Of course, your monthly bill will vary depending on your frequency of coffee maker usage in one day and in one month, the wattage of your coffee maker, its running time, and the cost of kWh in your area.
      The above is merely an example for you to understand the contribution of your coffee maker to your utility bill.
      Can You Use Solar Generator to Power Coffee Makers?
      Do you wish for a sustainable energy source that will also reduce your utility bills? Solar is your solution. Utilizing the sun’s energy, it is eco-friendly and an inexhaustible power source. No matter how many watts does a coffee maker use, solar devices will keep not only your coffee makers but also your other appliances running for a long time.
      bluetti ac180
      The BLUETTI AC180 Portable Power Station is your go-to solar power station owing to its portability. Along with its remarkable capacity, output, recharge ways, and control app, you will surely love this power station for your home. You can easily place it in the kitchen, effectively powering your coffee maker and other household devices.
      Key features:
      • With a 1,152Wh capacity and a 1,800W AC output, your house will always have the power to operate your coffee makers and other devices.
      • It has 11 output ports, allowing you to plug in your coffee maker, along with many other electrical appliances, at the same time.
      • You can recharge this power station using four ways - AC, solar, car, and generator.
      • You can monitor and control this power station through the BLUETTI app. Convenient, isn’t it?
      The BLUETTI Elite 200 V2 is a high-capacity portable power station designed for home backup, camping, road trips, and off-grid power. With 2,073.6Wh capacity and 2,600W AC output, it can support a wide range of appliances, from coffee makers and refrigerators to cooking equipment and other high-demand devices.
      Key features:
      • 2,073.6Wh Capacity: Provides substantial stored energy for appliances and electronics when grid power or electrical hookups are unavailable.
      • 2,600W AC Output: Handles a broad range of everyday and higher-power appliances, making it suitable for both home backup and outdoor use.
      • LiFePO4 Battery: Built for long-term use with a durable battery chemistry suitable for frequent charging and discharging.
      • Solar Charging: Pair the Elite 200 V2 with compatible solar panels to replenish power during camping, road trips, or extended off-grid stays.
      • Fast Recharging: Flexible AC and solar charging options make it easier to recharge between uses and maintain access to stored power when needed.
      • 15ms UPS: Provides backup support for compatible essential devices when an unexpected grid outage occurs.
      BLUETTI Apex 300 + B300K | Home Battery Backup
      The BLUETTI Apex 300 + B300K Home Battery Backup is built for households that need more stored energy and higher output for everyday appliances and unexpected outages. With 5,529.6Wh capacity and 3,840W AC output, it can support coffee makers alongside refrigerators, lighting, electronics, and other compatible household essentials.
      Key features:
      • 5,529.6Wh Capacity: Provides substantial backup energy for coffee makers and other household appliances, with a modular design that allows capacity to expand to 18,432Wh+ for longer backup needs.
      • 3,840W AC Output: Supports a wide range of everyday and high-demand appliances, allowing multiple compatible devices to run when grid power is unavailable.
      • LiFePO4 Battery: Designed for long-term home backup with durable battery chemistry and a modular B300K expansion battery.
      • 0ms UPS: Provides seamless backup for compatible essential devices when an unexpected power interruption occurs.
      • Smart App Control: Monitor power consumption, battery status, and system operation through the BLUETTI app.
      • Solar Charging: Compatible solar charging provides another way to replenish stored energy during extended outages or off-grid use.
      Wrapping Up
      We all agree we can’t live without coffee, the morning brew, what are you waiting for? Figure out how many watts does a coffee maker use and go for the most sustainable option, which is solar products. The BLUETTI AC180 Portable Power Station, the BLUETTI AC200MAX solar generator kit, and the BLUETTI AC500 Home Battery Backup will never disappoint you with their amazing features.
