How Does the BLUETTI AC300+B300 Compare to its Closest Competitor?
Portable power solutions have grown in popularity in recent years, providing users with a convenient and dependable source of electricity on the go. As more and more people look for ways to power their electronics, appliances, and tools without using traditional power sources, companies have come up with a wide range of portable generators that can provide reliable, long-lasting power in a small and portable package.
Among the most popular of these portable solar generators is the AC300+B300 by BLUETTI that offers a wide range of impressive features and advantages.
But, how does this portable solar generator stack up against other options in the market? This blog post will attempt to answer that very question. We will compare the generators based on several factors, such as power output, battery capacity, noise level, and pricing.
BLUETTI AC300+B300 v/s 3000 Pro – A Comprehensive Comparison
Battery Output
Battery output, which is also called battery capacity, is how much electrical energy a battery can store and transmit. Typically, the output of a battery is measured in watt-hours (Wh) or ampere-hours (Ah) and reflects the amount of power that can be delivered over a given length of time.
The output of a battery is crucial when selecting a portable power solution since it influences how much and for how long the device can give power. A battery with a higher output, for instance, will be able to power more devices and run for a longer duration than one with a lower output.
The BLUETTI AC300+B300 offers a battery output of 3000W. This is considered to be quite a high output for any portable solar solution. 3000W is typically enough to power various high-demand tools and appliances, including refrigerators, air conditioners, and even some electric vehicles.
On the other hand, the 3000 Pro generator offered by a brand also offers 3000W of power. So, in this regard, BLUETTI’s product is pretty neck-to-neck with the 3000 Pro generator.
Battery Cell
The BLUETTI AC300+B300 generator contains a LifePO (Lithium Iron Phosphate) battery, while the 3000 Pro uses a Lithium-ion battery. While both types of batteries are commonly used for portable solar solutions, LifePO brags a number of advantages over its Lithium-ion counterpart.
For one, LifePO batteries have a significantly higher power density that allows them to deliver significantly higher amounts of power in shorter durations. Other than that, they are also more stable than Lithium-ion batteries, and are, therefore, less prone to issues like overheating or catching fire.
Finally, a LifePO battery has a considerably longer lifespan, meaning you will be able to use the AC300+B300 battery for a longer time period before having to replace it.
Considering these unique advantages associated with the AC300+B300’s LifePO battery, BLUETTI certainly takes the cake over the 3000 Pro’s Lithium-ion battery as far as the battery type is concerned.
The amount of electrical energy that a portable solar generator can store and provide to power electronic devices, appliances, or tools is referred to as its capacity. This capacity, which is typically measured in watt-hours (Wh) or ampere-hours (Ah), represents the total amount of energy that the generator can store and deliver.
Capacity is another important factor to consider when comparing portable solar generators. This is because it helps determine how long the generator will be able to power your devices. The higher a generator’s capacity, the longer it will be able to supply power before needing a recharge.
BLUETTI’s AC300+B300 offers a whopping 24.5kWh, or 24,500Wh, of battery capacity. In contrast, the 3000 Pro has a battery capacity of 3.024 kWh, or 3,024 Wh. In other words, BLUETTI’s battery capacity is over eight times higher than that of 3000 Pro. Therefore, in terms of capacity, BLUETTI’s AC300+B300 is a great portable solar generator option.
Solar Input
Solar input, which is also called solar input power, is the amount of electricity that solar panels produce and send to a solar generator or other electronic device. This power comes from the photovoltaic effect, which is a way that sunlight is turned into electricity.
In the case of a portable solar generator, the solar input is an important factor since it affects how quickly the generator’s battery can be charged using solar power. With more solar input power, the battery can be recharged faster, allowing the generator to run for longer periods of time.
The BLUETTI AC300+B300’s large solar input of 2400W allows it to absorb and store large quantities of energy from the sun – energy that can then be used to power electronic appliances, devices, and tools.
In comparison, the 3000 Pro has a significantly lower solar input of 1400W, enabling it to store and generate considerably less amounts of solar energy. While this may be sufficient for some electronic devices or appliances, it is not likely to be enough for larger tools or appliances requiring more power. The AC300+B300 is certainly an excellent option in terms of solar input.
Smart App Control
BLUETTI’s AC300+B300 portable solar generator comes with smart app control. This means that users can control the generator through their smart devices using BLUETTI’s dedicated app. Users can remotely access and manage the generator, change settings, keep an eye on energy usage, and receive notifications and alerts.
BLUETTI’s smart app control gives users a number of benefits, such as the ability to control devices from a distance and the ability to track energy use and cut down on wasted energy. Not only does BLUETTI’s AC300+B300 portable solar generator offer great convenience to users, it’s also an effective way to reduce your energy bills.
There are not many solar generators in the market that are integrated with any kind of smart control application. Hence, this factor alone add’s another feather to BLUETTI’s cap.
24/7 UPS (Uninterrupted Power Supply)
Uninterruptible Power Supply, or UPS, is a sort of backup power system that supplies continuous, dependable power to your electronic gadgets and appliances, even during a power outage.
24/7 UPS systems are commonly used in data centers, medical facilities, and other settings where maintaining operations or preventing data damage or loss is critical. They are also useful in homes or offices where sensitive electronic devices or appliances must be protected from power outages or fluctuations.
The BLUETTI AC300+B300 is equipped with such a system, which allows the generator to provide continuous, reliable power to a variety of appliances and devices, thereby preventing data loss or damage. In addition, it also ensures that vital processes can continue uninterrupted during power outages.
This makes the BLUETTI portable solar generator more suitable for use-cases where dependable, uninterrupted supply is critical.  Once again, to the best of our knowledge, other portable solar generators in the market do not come with a 24/7 UPS.
Price
Price, obviously, is another top consideration for anyone looking to buy a portable solar generator. In this regard, the BLUETTI AC300+B300 and the 3000 Pro have significant price differences.
BLUETTI AC300+B300
The BLUETTI AC300+B300 is available for $2,999 as part of a limited-time offer as compared to the $3,599 that the 3000 Pro will cost you.
While a difference of $600 may not seem like a deal-breaker when observed in isolation, it is important to consider that the AC300+B300 portable generator offers a range of additional features and benefits that other generators, including the 3000 Pro lacks. This makes the former a considerably better value-for-money option – especially if you take action NOW.
BLUETTI’s AC300+B300 generator comes with a four-year standard warranty, which provides coverage for any malfunctions or defaults during normal operations for a four-year period from the day of purchase. This coverage includes repairs, replacements, and refunds.
On the other hand, the 3000 Pro comes with a three-year standard warranty, a year shy of BLUETTI’s four-year period. However, it also offers a two-year extended warranty beyond the three years, taking the warranty period to a total of five years. That said, the extended warranty may have certain restrictions or limitations that do not apply to the standard three-year period.
While the inclusion of the two-year period does make the 3000 Pro generator seem like a winner in this department, this will really depend upon the unique terms and conditions of the extended warranty. It’s Even then, we feel that this is a pretty close call when it comes to warranty.
Rewards and Discounts
BLUETTI’s reward system is a loyalty program that allows users to earn three BLUETTI bucks against each dollar spent on the company’s purchases. These points can then be exchanged for future purchase discounts or other prizes.
Customers can get rewards through the company’s reward program just by making purchases they may have already planned to make. Customers can get three BLUETTI bucks for every dollar they spend on BLUETTI products. These points can add up quickly and save them a lot of money on future purchases.
On the other hand, to the best of our knowledge, the 3000 Pro purchase is not associated with any such program. This means that customers are unlikely to be rewarded for their purchase.
Verdict
When the BLUETTI AC300+B300 portable solar generator is compared to its closest competitors, it is clear that the BLUETTI model offers more benefits and features.
The two generators – 3000 Pro and AC300+B300 – have the same power output, but the AC300+B300 offers a more stable and durable battery, significantly higher capacity, a considerably larger solar input, smart app control, and 24/7 UPS. In addition, BLUETTI offers a lucrative rewards program that can help its customers save money on future purchases.
Even though the 3000 Pro has an extended warranty of two years, the standard warranty is shorter than BLUETTI's standard warranty of four years.
Most importantly, BLUETTI AC300+B300 combines the higher performance and additional features with a lower price point, further concretizing its position as perhaps the best portable solar generator currently on the market.
As a result, we believe that the BLUETTI AC300+B300 is the superior portable solar generator. Its advanced technology, high-quality construction, and variety of features make it a dependable and convenient power source for a wide range of outdoor activities, emergency situations, and even an off-grid lifestyle. If you have any questions or concerns, feel free to get in touch with us.
Shop Bluetti
