Choosing a Diesel Generator for Camping? What You Need to Know
Many say diesel generators are obsolete; the world is embracing sustainability and adopting environmentally friendly options to fulfill power needs, is this true? In contrast, solar power and other renewable energy resources are efficient and reliable. Where diesel generators are noisy and polluting, these power sources are noise-less and clean.
As we know, diesel generators are not a sustainable power source and are more like a headache to campers. They take away the calmness of campsites and disconnect you from nature. If you want to immerse yourself in the serenity and behold natural wonders, a diesel generator is not something you should use.
If you are thinking about how to choose a diesel generator for camping recently, this article will give you more ideas to learn more about the diesel generator and find the best machine for your camping.
What Is a Diesel Generator?
Diesel generators produce power by converting diesel to electrical energy. It's similar to your car engine, which uses fuel to move the car. A generator uses diesel to produce a mechanical motion that rotates the alternator, ultimately producing electricity. Diesel generators are widely used in various applications, including backup power for homes, businesses, and outdoor events like camping.
These generators were an invention of the 1800s; they'd already greatly affected the climate. It's the 21st century, we've clean energy options, and it's our foremost responsibility to save the planet for future generations. Besides, diesel generators are also less efficient than renewable-based power resources. They're noisy, pose fire dangers, and are expensive to use.
How Does a Diesel Generator Work?
A Diesel generator is like a combustion engine; the diesel is burnt within the engine to produce high pressure and temperature. When the pressure and temperature exceed a threshold, they move the alternator connected to the engine. The alternator rotates inside a magnetic coil and induces an electromagnetic current. The coil carries the current and supplies it to the connected circuit.
That's how we receive electricity from diesel generators. In this process, excessive diesel is burnt, which produces Carbon Dioxide, a harmful gas that negatively impacts the environment. If you're not into science, take diesel generators as burning clogs for heat. In this case, the heat replaces electricity, and clogs replace diesel.
Pros and Cons of a Diesel Generator
Although the diesel generator was a marvelous invention back then, it is irrelevant today. There are places where it's extensively used, but in the current climate change situation, its usage is discouraged.
Diesel Generator Pros:
  • It produces a pure alternating current suitable for most appliances and equipment. More like plug-and-play.
  • They can sustain heavy loads and cater to needs requiring a continuous ac power supply.
  • Diesel generators are a reliable power source, given that you have enough diesel supply.
  • Compared with other generators in the same category, i.e., gasoline generators, diesel generators are fuel efficient and durable.
Diesel Generator Cons:
  • Most diesel generators require frequent maintenance to function correctly. It ranges from cleaning to oil change. In the same way, you need to maintain your car engine.
  • Diesel generators are harmful to the environment. They produce heavy greenhouse gases that adversely affect the environment.
  • The operating and initial costs are also high. The diesel generator comes with a hefty price tag and runs on costly diesel fuel.
  • Noise and vibration are also a bit concerning because these generators are very loud. And they tend to produce vibrations.
  • The diesel generators are heavy and bulky. It is difficult to move and operate them. Their portability is low and not suitable for camping.
BLUETTI EB3A
Portable Power Station
Whether it be a small blender, mini rice cooker, or small refrigerator, EB3A has got you covered
Check Discount
Limitations of Diesel Generators for Camping
Diesel generators are not suitable for camping for many reasons. They're banned or restricted in various national parks for their environmental impact. Here are diesel generator limitations for camping you should know:
Fuel Availability and Storage:
If you depend solely on a diesel generator to fulfill power needs, you'll require a large quantity of fuel and its equivalent storage capacity. Plus, sourcing and handling fuel is difficult and poses multiple hazards, i.e., bushfires.
Campsite Restrictions:
In national parks and regulated campsites, diesel generators are time-bound or completely banned. It's because of their noise and environmental effects. If you don't have power, your camping experience may not be much enjoyable.
Reliability Issues:
The diesel generator is a mechanical device and is more prone to malfunctions. During camping, if the machine runs into a problem, you'll be entirely out of power. The complexity of the machine doesn’t allow simple troubleshooting.
Weight and handling:
Diesel generators are bulky and not easy to operate. The generator will take up quite a good space if you're going camping. And its weight also makes it challenging to carry or handle. You'll have to adjust your baggage.
Environmental Effects:
Diesel generators burn fuel, produce greenhouse gases, and create high noise. The use of diesel generators affects the natural environment at camp locations. The surrounding habitat is also affected, especially native animals.
Alternative Power Solutions for Camping
Multiple clean energy power solutions for camping are more efficient and reliable. As environmental conscience is increasing among campers, diesel generators, and similar power sources are discouraged. The discouragement is also coming from campsite rules and regulations.
We're suggesting to you the ideal alternative power solution you can use for your next camping adventure. Hopefully, you'll recognize your social responsibility and act toward preserving our environment and our planet. Here are your options:
  • Solar Power
Solar power is a miracle; it is the sun's energy that produces electricity. Solar panels are the best alternative to diesel generators. They provide you access to clean and reliable energy to meet your demands. Solar power has no adverse effect on the environment; it is noise-less and completely maintenance-free.
Access to Solar power makes your camping experience comfortable and effortless—no need to kick-start the generator or worry about time-bound usage. Keep yourself easy and close to nature without limiting your power needs. Plus, most solar panels are highly portable and easy to carry.
To your surprise, BLUETTI is producing foldable solar panels designed for camping. They're portable, lightweight, and can fit in our bag. The BLUETTI PV350 SOLAR PANEL produces 350 watts of power to fulfill your needs. The panel effectively captures solar energy to keep your appliances running. It is made using quality material to withstand wear and tear. The panel is also waterproof; you don't need to hurry to take it in during the rain.
bluetti ac180
BLUETTI solar panels are best used with BLUETTI AC180 Portable Power Station; it packs power you can use anytime. It provides a massive 1,800W AC Output power backup that can last a lifetime. You can connect all your devices and appliances to the device and run them all day long. Unlike diesel generators, it is completely noiseless. The device's highlight is its connectivity and control through a mobile application.
  • Portable Power Stations and Solar Generator
Portable Power Stations are a more reliable and cleaner alternative to diesel generators. They store energy in an integrated battery. The power is retained and can be used when needed. The battery is recharged and reused, making it a renewable power source. These power stations offer you convenience through multi-recharge technology; you can use any power source to charge them.
The BLUETTI is a leading manufacturer of portable power stations designed for outdoor use. They offer complete solar generator kits that keep you off-grid anywhere. During camping, you'll no longer stop for power or hunt down power sources; you'll enjoy ultimate energy independence. The product to highlight is the latest BLUETTI AC300 + B300 Solar Generator Kit.
bluetti ac300b300
The kit provides a 3,000W AC Output, enough to keep you moving for a week or more. You can recharge through the provided solar panels or any power source, ranging from a car generator to an AC supply. If you're afraid about charging speed, the power station is equipped with fast-recharge technology. The solar generator kit is easily controllable through a dedicated phone app. What else is left?
Related articles: Solar Generators vs. Gas Generators: Which Are Better for Camping?
How Much Solar Power Do I Need For Camping?
Diesel Generator and Solar Generator Compare Overview
Here's the comparison between your two power solutions for camping adventures. Make sure you take the decision, keeping in mind the environmental vulnerability of our planet.
Sno.
Characteristic
Solar Generator
Diesel Generator
1.
Camping Suitability
High
Low
2.
Neutral
Negative
3.
Noise and Emissions
None
High
4.
Portability
High
Low
5.
Maintenance
Low
High
6.
Costs
Low
High
Camping helps you detoxify city toxins and spend time closer to nature. You feel refreshed and behold the natural wonders. It is unjustified if you're going camping and taking a diesel generator with you. Although the device will fulfill your power needs, it'll pollute campsites' clean and green environment. The biodiversity and animals will be highly affected.
Using a clean energy solution, as we suggested, would be better. You'll enjoy your time, and the environment will not be affected. It's a win-win deal; therefore, be a responsible citizen of the planet, and take care of the environment. Hopefully, you go to your next camping trip with a change.
