The BLUETTI EB3A became a popular compact solar generator for camping, road trips, emergency backup, and everyday portable power. With its compact design, LiFePO4 battery, and 600W AC output, the EB3A offered a practical option for users who wanted reliable power without carrying a large power station.
If you're researching the EB3A today, you may also want to consider the newer BLUETTI Elite 30 V2 Portable Power Station, which builds on the compact 600W power class with updated battery life, charging, and UPS capabilities.
What is the BLUETTI EB3A?
Put simply, the EB3A is a solar generator capable of transforming DC into AC electricity.
In essence, the EB3A comprises the following technology:
- LiFePO4 Battery
- MPPT Charge Controller
- Pure Sine Wave Inverter
- A whole bunch of high tech electronics
What are the Features of the BLUETTI EB3A?
Lightweight
The EB3A has been designed to be more energy-efficient than traditional gas generators. By design, the EB3A is so super light in terms of weight, meaning it makes the perfect travel companion.
600W AC Pure sine wave inverter
The EB3A houses an impressive 600 watt pure sine wave inverter that allows for a 1200 watt surge. Even though it's compact, it could allow you to power a small refrigerator.
Fast charging
EB3A fallows for 430W fast charging that enables an 80% charge within 30 minutes, the same amount of time it takes you to drink a cup of coffee or have a chitchat with a friend.
6 Ways to recharge
The Bluetti EB3A can be recharged in multiple different ways:
- AC (mains electricity)
- Solar panels
- Car
- Gas generator
- AC + Solar
- AC + Adapter
Latest LiFePO4 battery technology
The LiFePO4 battery EB3A adopts possesses a natural advantage due to its remarkable thermal and chemical stability, giving you better performance and longer life cycle (2,500 cycles to 80%). While the built in BMS is monitoring and protecting your device from every potential risk, at all times.
9 Different outlets
The EB3A has enough ports for simultaneous charging, such as:
- Classic AC and DC outputs
- 100W Type-C
- Car socket
- Wireless charger
BLUETTI EB3A Specifications
OUTPUT |
AC Outlets: 2 x 120V/5A Outlets 600W In Total |
Inverter Type: Pure Sine Wave |
Surge Power: 1,200W |
USB-C Port: 1 x 100W Max. |
USB-A Port: 2 x 5V/3A USB-A |
DC Outlets: 1 x 12V/10A (Car Outlet) 2 x 12V/10A DC 5521 (5.5mm Outlets) *All Regulated. |
Wireless Charging Pad: 1 x 15W Max. |
INPUT |
AC Charging Cable (Standard Mode): 268W Max. |
AC Charging Cable (Turbo Mode): 350W Max. |
Solar Input: 200W Max, VOC 12-28VDC/ 8.5A |
Car Input: 12/24V from Cigarette Lighter Port |
Maximum Input: 430W, with AC and Solar Input Simultaneously |
RECHARGE TIMES |
AC Charging Cable (Turbo Mode 350W): ≈1.3-1.8 Hours |
AC Charging Cable (Standard Mode 268W): ≈1.5-2.0 Hours |
Solar (200W): ≈1.8-2.0 Hours (With prime sunshine, ideal orientation and low temperature) |
12V/24V Car Outlet (100W/200W): ≈3.2-3.7 or 1.9-2.4 Hours |
AC + Solar (430W): ≈1.2~1.7 Hours (With prime sunshine, ideal orientation and low temperature) |
Dual AC (430W): ≈1.2~1.7 Hours (With optional BLUETTTI T200 Adapter) |
GENERAL |
Pass-through Charging: Yes |
Weight: 10.14lbs/4.6kg |
Dimensions (LxWxD): 10.04*7.09*7.20in/255*180*183mm |
Operating Temperature: -4-104℉ (-20-40℃) |
Storage Temperature: 32-104°F (0-40°C) |
Certifications: UL Standard, CEC, DOE, FCC, CA Prop 65 |
Warranty: 24 Months |
BLUETTI EB3A vs. Elite 30 V2: What's the Difference?
The BLUETTI EB3A and Elite 30 V2 are both compact 600W portable power stations designed for everyday charging, camping, and backup power. While they share a similar power class, the Elite 30 V2 introduces several upgrades in capacity, battery lifespan, USB-C output, and UPS performance.
Feature |
BLUETTI EB3A |
Battery Capacity |
268Wh |
288Wh |
Rated AC Output |
600W |
600W |
Battery Chemistry |
LiFePO4 |
LiFePO4 |
Battery Life |
2,500+ cycles to 80% |
3,000+ cycles |
Max. Solar Input |
200W |
200W |
USB-C Output |
100W Max. |
140W Max. |
Backup Function |
EPS |
≤10ms UPS |
Best For |
Existing owners and EB3A product research |
Current compact portable power needs |
Both models deliver 600W AC output and support up to 200W solar input, but the BLUETTI Elite 30 V2 upgrades the EB3A's 268Wh capacity to 288Wh, increases battery life from 2,500+ to 3,000+ cycles, boosts USB-C output from 100W to 140W, and adds ≤10ms UPS switching. These upgrades make the Elite 30 V2 a more capable current-generation option for compact portable power.
If you are looking for lightweight, portable power to take along with you on a camping trip, then the EB3A should be your goto choice.
One important note from us would be to make sure you understand your energy needs before purchasing any solar generator on the market.
Not all solar generators are made the same, in terms of what they can power and for how long.
Just remember this rule of thumb, the more things you want to power, the larger capacity solar generator you will need.
The EB3A was designed for compact, everyday portable power, but the right upgrade depends on how you plan to use it. If you mainly need power for phones, laptops, cameras, lights, and other small devices, the Elite 30 V2 keeps the same compact 600W power class while offering 288Wh capacity and updated features. If your trips are longer or you want to run higher-demand appliances such as a portable fridge, coffee maker, or other camping gear, the Elite 100 V2 steps up to 1,024Wh capacity and 1,800W output, giving you more runtime and flexibility for camping, road trips, and backup power.
