Electricity has become an integral part of our lives, and we cannot even think of living a day without it. But power outages and grid failures often creep into our lives, destroying all the balance.
As per an article from Fortune, approximately two-thirds of the US populace is facing the risk of power outages. But nothing can keep Americans from electrifying their houses. They are investing in solar power stations because solar energy is safer, cleaner, and more reliable than conventional grid power.
However, knowing the power station's amps, watts, voltage, etc., is crucial to ensure your devices never skip a beat. This comprehensive article will outline how to calculate amps, watts, and volts and also recommend three top-notch portable power stations with high amperage, watt, and volt values.
What Are Amps, Watts, and Volts?
The knowledge of basic electricity terms like amps, watts, volts, and ohms becomes crucial when it comes to the fundamentals of electricity.
These electrical terms are handy for any power station since they play a vital role in determining their compatibility with your household or office appliances. Conversely, if you power your equipment using the wrong voltage battery, it will fail to work.
The best thing about these electrical terms is that they are all connected, and you can calculate them using a simple formula. For instance, you can determine how many watts a device consumes by multiplying amps and volts.
What is An Ampere?
Amperes, commonly called amps, represent the number of electrons that flow through a certain point per second. In other words, it measures the current flow through an electrical circuit.
In pure mathematics, amperes are equivalent to watts divided by volts of a specific device. Its formula is
Amps = Watts / Volts.
It means if you know the watts and volts of an appliance, you can easily find its amps. For example, if the watts and volts of an electronic device are 1,920W and 240V, respectively, the ampere value will be
Amps = 1,920W / 240V = 8A.
Amperage, expressed in amps, indicates the strength of that currency. The larger the amperage, the more current can flow through the circuit.
What is A Watt?
Wattage, AKA watts, measures the power an electric device consumes. It can be defined as the "electricity at work" or power a device needs to work.
In mathematical terms, it is the product of amps and volts. Its formula is
Watts = Amps × Volts.
For example, if a household appliance uses 15 amps and 240 volts, the wattage value will be:
Watts = 15A × 240V = 3,600W.
The higher the wattage value, the more the output and power of an electronic appliance. Below is a wattage table for common home appliances:
Home Appliance |
Wattage / Power Consumption |
1-Ton Inverter AC |
900W |
1.5-Ton Inverter AC |
1,200W |
Home Refrigerator |
350W ~ 780W |
Modern Deep Freezer |
80W ~ 300W |
Ceiling Fan |
75W |
LED Light Bulb |
10W |
Washing Machine |
500W ~ 1,400W |
Clothes Dryer |
1,800W ~ 5,000W |
Bread Toaster |
800W ~ 1,500W |
Keurig / Nespresso Coffee Machine |
900W ~ 1,500W |
Desktop Computer |
60W ~ 300W |
Laptop |
30W ~ 200W |
Electric Stove |
3,000W |
Electric Rice Cooker |
300W ~ 1,100W |
Microwave Oven |
2,000W ~ 5,000W |
Home Internet Router |
6W |
Inkjet Printer |
30W ~ 50W |
Electric Iron |
800W ~ 2,000W |
Space Heater |
750W ~ 1,500W |
Dehumidifier |
214W ~ 970W |
24-Inch LCD TV |
50W |
24-Inch LED TV |
35W |
What is A Volt?
Voltage, typically known as volts, is the pressure or force an electric current needs to flow past a wire. It also measures the speed at which the electrons flow through the circuit.
Large household appliances like refrigerators or deep freezers, washing machines, air conditioners, and heaters operate at 240V, while smaller gadgets like energy bulbs, computers, and phone chargers work at 120V.
In numerical terms, volts are equal to the wattage of an appliance divided by its amps. Its formula is
Volts = Watts / Amps.
If an appliance's power consumption is 1,000 watts and its ampere value is 25 amps, the volts can be calculated as
Volts = 1,000W / 25V = 40V.
What is An Ohm?
An Ohm measures the resistance inherent in an electric wire when the electrons flow from high to low. If I state otherwise, it signifies the electrical resistance between two points of a conductor.
In technical terms, when 1V of constant potential difference is applied to these points, and a current of 1A is produced, the natural resistance will be one Ohm. Its formula is
Ohm = Volts / Amps
Or, Ω = V / A.
For instance, if there is 240V and a current of 12A, the natural resistance of the conductor will be
Ω = 240V / 12A = 20 Ω.
The Relation Between Amps, Watts, and Volts
Electrical mathematics may seem daunting to understand. Well. Ohm's wheel law is one simple and quick way to understand the relation between amps, watts, and volts.
Still on the fence? Here is an example to help you understand how the wheel works. Suppose you want to install an electric heater at your home and finalize a 1,500W heater. Now, you have to determine the circuit needed for your heater to run smoothly.
Suppose the heater is rated at 1,500W and needs 240 volts to operate. As we already have wattage and voltage values, we calculate amps using the formula from Ohm's wheel.
I = W / E,
where I represents Current, W is Wattage, and E is Voltage.
Substitute the specific values:
I = 1,500W / 240V = 6.25.
As a typical US household operates the heater for 7 to 8 hours on a frosty winter day, apply a safety factor of 150%.
I = 6.25 × 1.50 = 9.375A.
This means your electric heater would require a 10A circuit for optimal working.
Voltage, Current, and Resistance
According to Ohm's law, voltage, current, and resistance relate to each other. Their relation can be represented as
V = I × R,
where V is Voltage, I is Current, and R is resistance.
This equation indicates that an increase in voltage will directly increase the resistance while the current will remain the same.
Power, Voltage, and Current
Now, after all the above discussion, you will not be surprised to know that power, voltage, and current are also connected. Below is a simple equation highlighting their connection:
P = V × I,
where P denotes Power, V is Voltage, and I is Current.
This equation shows that the power (output) can be increased by either increasing current or voltage.
BLUETTI Solar Power Stations Explained
When choosing a power station, you should pay attention to its amps, watts, and volts. A battery backup with more watts can keep your devices working for longer, and the ones with more amperes will charge your devices faster.
BLUETTI is a class-leading solar company that manufactures portable power stations of different sizes. Its compact, durable, and safe power stations can be used for living off-grid, traveling, or camping.
BLUETTI Elite 100 V2 Portable Power Station
The BLUETTI Elite 100 V2 is a versatile portable power station for home backup, outdoor activities, and everyday power needs. Its combination of portable battery storage and high AC output allows it to support a wide range of household electronics and appliances when access to grid power is limited.
The Elite 100 V2 also supports fast and flexible recharging, helping you get the power station ready for unexpected outages or upcoming trips. With BLUETTI app control, you can conveniently monitor and manage the power station from your mobile device.
With multiple output options, the Elite 100 V2 can keep phones, laptops, lights, small appliances, and other essential devices running, making it a flexible option for both backup and off-grid power.
For users looking for a balance between portability and power, the Elite 100 V2 provides a practical solution for emergency backup, road trips, camping, and other situations where reliable portable electricity is needed.
BLUETTI Elite 30 V2 Portable Power Station
The BLUETTI Elite 30 V2 is a compact portable power station designed for lighter everyday power needs. Its portable design makes it convenient for keeping essential electronics powered during short outages, camping trips, road trips, and other situations away from wall outlets.
It can support multiple everyday devices such as phones, laptops, cameras, lights, and other small electronics, providing a convenient backup power source when access to grid electricity is limited.
With flexible recharging options, including compatible solar charging, the Elite 30 V2 is easy to incorporate into a portable or off-grid power setup.
For users who need more power and energy storage, the BLUETTI Elite 200 V2 Portable Power Station provides 2,073.6Wh of capacity and 2,600W of AC output. This makes it suitable for powering a wider range of appliances and electronics during outages, extended outdoor trips, and off-grid use.
The Elite 200 V2 supports flexible recharging options, including solar charging, allowing users to replenish stored energy when grid electricity is unavailable. Its fast charging capability also helps reduce the time needed to prepare the power station for backup or outdoor use.
With its higher capacity and output, the Elite 200 V2 is well suited to users seeking a more powerful portable solution for household essentials, RV trips, camping, and temporary backup power.
Final Word:
The amps, watts, voltage, and resistance formulas can help calculate the power consumption of your appliances. Once you become acquainted with how much power your devices need, you can easily determine the needed portable power station size.
Based on your energy needs, you can choose the BLUETTI Elite 200 V2 for higher power needs. Or, have a look at other flexible options on the BLUETTI website. You will surely find a budget-friendly yet reliable backup solution for your needs there.
