First of all, RV is a shortened form for the term recreational vehicle. This is a vehicle that includes quarters good enough for a living condition. However, the accommodation being discussed here is not just for camping alone.
Statistics show that many people living in American use RVs as stable apartments. The vehicle is big enough to take in humans as much as possible, and also, some big RV comes with expandable slides, and it makes the vehicle get wider when it is not in motion; this is called slides out.
The size of a moderate RV vehicle is 40*8*12 feet. With a vehicle, this enormous a very high-quality power supply is required to keep it moving.
Most people use solar energy, but solar panels are limited by many things and maybe disappointing when it starts malfunctioning. Using a power station is much more reliable, especially a good one which may be difficult to get.
However, we will be offering you recommendations on the best power station for RVs and some information on the product.
For high-budget
BLUETTI AC200MAX EXPANDABLE POWER STATION
This package comes with a good 2048Wh ultra-durable LFP cells and a 2,200W full power wave inverter. This would be an excellent choice off-the-grid which means on a road trip or as stable accommodation. One of the perks of the PS is that it has up to 16 outlets which makes it possible to serve all the electricity needed simultaneously.
It can power a 150-watt refrigerator for 15 to 28 hours or a 10-watt lamp for more than 50 hours.
In addition, AC200MAX power station can hold up to two BLUETTI B230 (2048Wh each) or B300 (3072Wh each) battery modules, connecting them can increase the total capacity to an astonishing 8192Wh! Equipped with a AC200MAX power station on the RV, you can avoid worrying about electricity consumption at all.
For low-budget
BLUETTI EB70s 716WH/800W PORTABLE POWER STATION
It is much cheaper than AC200MAX power station and comes with a 716Wh capacity and 700W rated wattage, and this is ideal for an RV. It could also work to power up appliances like mini-fridge, air conditioners, phones, laptops, and many others. It has in total 12 outlets and can simultaneously take on a lot of appliances.
BLUETTI EB70 power station has 4 charging ways, and also doesn't take much time to charge fully.
Can the portable power station for RVS Power up Air Conditioners or Fridges?
Solar generators are batteries powered up differently, one of which is by solar panels and another is by direct electrical power.AC200MAX can power a 150 watt refrigerator for 15 to 28 hours, or an 8000 BTU air conditioner for 3 to 7 hours.
Choosing a power station for air conditioners or fridges, you must consider the following questions:
First, you have to consider the appliances you have and how much energy would be required daily to power everything electrical you own. You would also consider how many batteries you need based on how many days you would be camping or traveling.
You also need to consider placing the panel as some roofing styles might hinder the correct placing of the solar panel. You cannot place the solar panel where it would get stepped on. Once there is a crack on the panel, it tends to reduce the power supply. It should also not be covered by a shadow of any kind. So a good placing is key.
After that, you consider that there are a lot of panels in the market and the prices are not the same for all of them. The difference in price lies in the type of panel you choose from. To get a very good and efficient one, the price is usually higher. Flexible solar panels are very modern and don't occupy as much space as their counterparts, but the price might be higher.
Getting the best solar panel would be difficult due to the number of panels we have laying all over the market; however, we have some recommendations, so you don't make a wrong choice.
BLUETTI PV120 120W SOLAR PANEL
One of its perks is that it is outrightly affordable, notwithstanding its high quality. It is designed to be durable, and it has a strong water resistance.
it lasts long.
It is scratch-resistant due to its long-lasting ETFE material on the surface.
It is compatible with most solar generators.
It is foldable and portable.
The BLUETTI PV120 is very comfortable to carry and set on any road trip or camping.
This product is lighter, cheaper but meanwhile, it has a lower peak power.
BLUETTI PV200 200W SOLAR PANEL.
It is designed for the most portable power station.
Like the PV120 solar panel, it is also foldable and easy to carry around, and very good for coming as it can be packed up well and opened well.
It is very durable, and stores more energy, which would last for a much longer time than its counterpart. This product is much more expensive, but it has a higher peak power which is very important.
How does a Solar Panel work?
Solar panels primarily get their energy from direct contact with sunlight.
They can power other appliances by the conversion of the energy produced by the sun into power.
So by this, electricity and heat are the two forms of energy generated from the sun for man's consumption.
They are both generated through the use of solar panels, which come in different sizes.
Power generated through the sun is a clean source of energy, and unlike other sources of energy, it creates no harmful greenhouse gas emissions.
The panels are created from silicon which is directly installed in a metal panel frame with glass protecting it.
When sunlight hits the thin silicon layer on the top of solar panels, they tend to knock off electrons from the silicon atoms.
It creates an electric current, and the wiring in the solar panels captures this.
Also, solar PV panels produce electricity while solar thermal panels generate heat.
While they both get their energy from the seller source, which is the sun, the system of technology is not the same.
Where should I place the Solar Panels on RV?
The best place to use a solar panel is where the sun directly hits it, and for an RV, it is most likely on the vehicle's rooftop.
However, it is designed to harness the most power when the sun hits its top surface perpendicularly.
One of the keys to getting enough power is to make sure the sun hits the right place properly, and having a correct tilt to the right angle will ensure the sun gives out as much energy as possible.
Q: Can I plug my RV into a portable power station?
A: Portable power station has a very small amount of power supply and might not carry a big RV, so it is advisable to use a power generator or a solar panel of high quality.
Q: What is the strongest portable power station?
A: According to my search and discovery, as at the time this article was written, the best portable power station is the BLUETTI AC200MAX portable power station, the best portable power station that has been tasted. It has so many outlets for charging devices, and it is strong, reliable, and fast. It weighs 28.2Kg and can serve for a long period. It is not cheap and as such costs a great deal but is also very efficient.
Q: How long do portable power stations last?
A: This depends wholly on the power station in question because although they are all power stations, some have more capacity than others. It also depends on where it is charged as some sources inputs more energy than the others.
Q: Can a power bank run a fridge?
A: Yes, it can, but in venturing this, there would be a focus on a specific kind of power bank. This one is called a power station, and it can store a lot of energy equal to powering up a fridge.
